Root HDMI not working CM7
2strokenut
Hey guys got one more issue with CM7 I just bought an HDMI cable today and it looks like its not working. I tried the cable with my buddies Droid X and it works for that so I'm assuming it has something to do with my ROM, possibly. Was HDMI out one of the things not working with CM7? Everything else on it is flawless.
Thanks
Thanks
Depending on what release or nightly you are running, there may be issues. Have you flashed a custom kernel? That can play a part in functionality also.
well i checked the change log for both your tiamat kernel and cm7 and both have support for hdmi mirroring by teamwin. which app are you using? what exactly happens when you try it?
here are the apps that you can use:
https://market.android.com/details?id=com.teamwin.hdmi&feature=search_result
https://market.android.com/details?id=com.orrebmas.fullhdmifree&feature=search_result
cm7 only supports hdmi mirroring you need the actual app to make it work.
please note that these are the free version. i would suggest to buy or donate to the devs as they work hard to make these awesome goodies for us:
https://market.android.com/details?id=com.orrebmas.fullhdmi&feature=more_from_developer
https://market.android.com/details?id=com.teamwin.hdmi.donate&feature=search_result
Ok great thanks a bunch! Yeah these developers really put a lot of work into this stuff.
