AndyOpie150
<strong> <a href="http://androidforums.com/optimus
There's your problem! Woohoo.
If you read the first dozen posts you will see that mkbkr1 has set this up to be used without a PC.
I made the same mistakes when I was helping check out the functionality of everything in his tutorial.
You can't download the files to a PC. They have to be downloaded straight to the phone.
Just one thing, I have to move them from Download folder to root of SD card, I figured that out. The guide says They are (.img) but they say (.bin). Do I change the extention on the file, or type (.bin) in Terminal Emu instead of (.img)... or nothing except renaming them? The also come through as a alphanumeric file name that makes no sense, I know how to rename it, I tried to use (.img) at the end and it yelled at me.
Or am I still doing something wrong?
