Actually not the soldered end of anything it the rear of the led light ,the socket is not sealed at all ,i have put a iphone silicon port protector in mine to stop the ingress of dust.Sorry, but you are seeing things .... what you're seeing is the soldered end of the headphone socket, nothing made of glass .......
OK so it was some mms too long. I is still too deep and the headphones will not work pushed all the way in.A couple of 'cms' is VERY long indeed![]()
The LED light just below it is exposed through the headphone socket when you have it plugged in charging or when a notification occurs, I can see it at night since I lay the phone face down (rubber skin) and the light reflects off my wall through the headphone socket.
That i didnt know ,thanks for that ,had always wondered why they left it opentrue but the bottom of it is deelper than the led light. on most headphone sockets there is a clear plastic bit. its a dust cap.
