I finally discovered a solution to the volume issue in the Hero. I replaced the Hero with a Galaxy S II. ;-) Wow!
Hello,
Any solution to this issue yet? I also own a Desire and the headphones volume is way too high. I am using the standard headphones and do not want to purchase a new set. In the office I use the lowest media volume setting, which is not low enough. I hope anyone makes a good app for this.
Regards,
Roy
Have you tried the "Fine Volume Control" app?
There is a great app in the Google play Store called ExtraVolumeSimple. I know it sounds like the opposite of what you want, but it is free. And it can decrease the volume of your music, and other media volume if you move the extra volume into the negative numbers. It is a pretty neat app. I recommend this. Good luck.Hello there.
First of all, hi, I'm Nick and this is my first post ever, I'm glad I registered on these forums which seem very, very useful.
I have a simple question. I use in-ear headphones which usually perform at very high volume. That is to say, I have to put the volume very low on the phone for an optimal use.
However, my HTC Desire, even at the lowest possible volume, is still too loud for my fragile ears. Is there any way to fix this and change volume settings?
Cheers.
