Root Help a Noob! CM7 not remembering settings until after reboot
heyki
I recently installed a CM7 ROM by PlayfulGod on my Optimus M and everything was going fine until I noticed that some of the setting were not being saved.
I checking off 'Unknown Sources' in the Applications and noticed that every time I exited settings and returned to them 'Unknown Sources' was still not check off.
This was happening with most of the setting except a few, those being the setting in 'Performance' under the CyanogenMod settings.
The only way the setting are permanently saved are if I stay in the settings menu that I want to change, make the changes and then reboot my phone from there without exiting the menu.
Is there a fix to this or should I look for another ROM?
This is very common when installing new ROMs, I'll just link to a post that helped with the same problem: click here
Thanks for the link! Sadly, I have already tried fixing permissions and it does not seem to help the situation. I'm going to re-install the ROM and right away fix the permissions to see if that does anything to solve the issue.
So I reinstalled the Rom and fixed the permissions and everything seems to be going well. I restarted my phone and the settings not saving issue started up again so I fixed the permissions and restarted the phone and it stopped. Furthermore what other roms would you guys suggest?
I use backside. I have no problems with it, once I fix permissions.
I will give that one a try then if this rom keeps giving me issues. Also, can I find it here on the forums?
if you use clockwork recovery their is a thing in advanced settings to fix permissions. :)
I tried install the clockwork recovery but it could not get it to function properly. If you could give me some pointers that would great!
Lastly, a new problem has arisen. My network bars do not stay green and most of the time only stay white unless I am connected to wifi then switch back to my regular network.
I know this has to do with a connection to Google services but when the bars are not green I can not use any internet related applications.
Does this have to do with permissions or this a new problem completely?
Different issue. Go to playfulgods wiki. He has the clockwork mod recovery. And use flash image GUI. Google it to find it. Or just get it from I believe windows roms. Or kelsos rom.
Well first off do you have good signal where your at? And whose rom are you using.? Did you do a data/factory reset, clear cache and dalvik cache before flashing the rom. Sometime their can also be a delay in your service not connecting right a way.
On average my phone gets about 2 bars of signal strength. I did a data/factory reset, cleared the cache and the dalvik cache before I flashed my current rom.
