did nandroid backup. thanks Andy.
Bad Blue mentioned that the best ROM for our phone is the Mirage. i cant see it in the list of ROM's ,in the "all things root" section.
unless its under an abbreviation or something, and i can't tell which it is.
where can i find it?...or if you think i should flash another one, which would it be.
i don't have the knowledge yet to tell the difference...
also, do i need gapps for the Mirage?
few questions:
what gapps are we talking here? basic operating apps like camera, gallery, etc..that are essential for the phone, or apps that we just download from the app store..?
do they come w the new ROM?
also, i noticed the dolphin browser works better than the stock. since i downloaded the dolphin, can i uninstall the stock browser?...will i get a new and better browser w the new ROM automatically?
i will go over the guide for flashing the custom ROM few times before i flash. it seems pretty simple. i just wanna make sure i get the whole thing understood.
..and finally, from what i understand, from now on all i have to do is download a ROM/theme..etc, put it on the root of sd card and go into recovery to flash, correct?
..i know its a lot of questions, im just trying to make sure i get the whole concept.
thank you in advance Andy
