Root help before flashing cyanogenmod 12.
sonyboyj
I got a galaxy note 8. i rooted using chainfire auto root. then used flashify to flash twrp. now my question is i heard you need to unlock bootloader before flashing a rom. how do i know if mine is locked or not. i have the GT-N5110 model if that helps.
also i cyanogenmod as safe as googles stock rom. and where do i get the Gapps.zip thx.
If you managed to flash twrp then your bootloader is unlocked.
Yeah cm is pretty stable and you should find a link to the gapps in the same place as the rom
