i will try that, about how much time?
so its been more than 8hrs, i press power button and nothing..
i tried, and nothing
As brian706 already suggested you should go to the #juopunutbear IRC channel via the support page on the unlimited.io website and tell them that. It can't hurt anything and they have dealt with a lot of failed attempts at the wire trick.i was doing s-off and the wire got stuck in one of the little holes
first, i followed instructions, did wire trick, phone vibrated and rebooted to juopuntu screen and wire was still on, after about 5 sec i was able to remove it..and the controlbear said *do wire trick now* again..it never said *successful*..at that point my pc gave me *couldnt install drivers for phone* notifications, then controlbear couldnt find a device.. and my phone was off..couldnt do anything to it since then.
i dont understand their chat thing..no one seems to be online right now..
A lot of the people that provide support there are in Europe and Asia. You might do better trying again later tonight given the time difference.so far nobody is there. it is the weekend so peeps might be out so just be patient which i understand is hard to do when your phone is in the state that it is in.
I have no idea if this will help you but take the battery out and thump the back of the phone not hard. I no everybody like wtf but I thought my phone was dead I thumped it and wala it turned on idk if the thumping helped but I just wanted to give u a option. I wanted to throw my phone so I thumped it
