Sadacoustics
Im good w/ windows but needless to say a noob in the android os. I rooted my lg optimus v using gingerbreak. Here is the problem ive learned how to root and im sure I couldve done it manually if I took my time but I just decided after weeks of deliberation to go the gingerbreak route. I have rom manager,superuser,and androzip installed also. After the root and reboot I opened rom managerand flashed the clockwork mod recovery which was successful. Now heres where I got lost so PLEASE correct me! I will take any suggestions that I can since im new to this. I was following a tutorial in a seperate forum and the next step was to boot into recovery which can b done using rom manageror by holding home+vol down power. Well I did just that I clicked onto the recovery and then clicked aosp mod. Idk what happened but I saw the lg logo and then instead of it going into recovery mode, it stayed on a black screen. Now I let it sit for 20 mins at least and after waiting was forced to remove the battery and power back up. I kno you prolly already know what happened next right? Since I was trying to wipe cache and wipe delvik cache so after I started my phone back up it wiped everything. I was lucky that all I had to do was snyc mygmail so I got all my contacts back but I still dont know what to do or if its bricked. Ive tried to boot in recovery mode several times following the 1st attempt. I still get that black screen and im sure if I would let the black screen up for an hr still nothing would change. I still would have to remove my battery and risk losing everything again. Please any help would be greatly appreciated...all I was trying to do was install a new version of android. Android 2.3.4 to b exact. Btw sorry for such a long post and if its in the wrong area I just figured I needed to explain in as much detail as possible in order to get the correct solution. Please help and thanks.
