Help HELP! Can't Flash With Odin!!
Hi people, I'm having a problem with my phone, I've had 2 lines show up at the top of my screen in the past couple of days. They're both multi-coloured and definitely look glitchy. They show up even in boot screens, fastboot, recovery, etc.
I thought it might have been a problem with Galax0 that I was running, so I tried to re-flash it with Odin, and Odin seems to finish, but the phone does not actually get flashed. It stays at my previous firmware, with all apps installed, but when it reboots with Odin, the screen doesn't work (except in between the two lines at the top, so I can just see the bar at the top). I pull the battery and reboot, and it works, but is very glitchy.
Do I have a H/W problem?
EDIT:
Even after rebooting, it seems when the screen locks, I lose everything except the top .5cm or so.
EDIT 2:
Okay, so now I don't get the real screen ever. Just noise. Ugh.
i dunno mate, i was just reading when you were saying it wouldnt boot etc but reading properly, i dont know what those lines are about
have you dropped it recently?
