Root Help changing CM7 themes
Kcsuper
I've seen this before and i think I'm just missing one app. but what do I need to change themes. I currently have "Theme Chooser" but remember having something else... CM7beta5 Thank you
All I use is the theme chooser and the themes that I've either picked up from the Play Store, or found on other sites and side loaded. You might be thinking of Metamorph or Ninjamorph though. Their use isn't mandatory but some themes come with zipped lock screens and other add ons that you can use the Morph apps for.
This is the main one that you need. The others are ThemeChooserThemes and ThemeChooserWallpaper. Those can be downloaded from the market.
This zip is can be flashed in CWM. Again, all thanks go to Bloodawn for making the ApkInstaller.zip available to us. All I did was add the files needed for the theme chooser.
Thank you Bloodawn
This will install the theme manager so you can select and apply your theme after downloading it from either the market or another site.
ThemesInstaller.zip
Don't forget you have to be using CM7 compatible themes. The CM9 ones won't work.. well none that I've tried LOL.
That's correct. You also need to use MDPI themes. Very few of the other type will work with the Prevail.
Thanks LordVincent90 I do have a question though. I didnt see an option on there to change the dialer color. When your on the phone, The green color. I would love to have it blue and change the android on the default picture to a better one. Anyway to do this? I found exactly what i wanted on the Hexed 3.5 theme for ctmod.
ROM toolbox? there a section on that app that had all the CM7 themes in one place
You'll need to hard theme it.
You don't need them. They help you find them but aren't necessary. I deleted theme chooser themes and I change themes often. Just find the themes in threads, make sure they're the right format, (mdpi in the prevail's case) download them, install reboot and you should be good. if it won't install then contact the developer
That's correct. You do not need Theme Chooser Themes but you do need the themes selector that has been removed from CM7beta5.t The link that I posted above contains it and can be flashed in CWM.
You will also need Theme Chooser Wallpapers from the which allows you to access the CM7 theme wallpapers.;)
A lot of the themes require that you follow the install instructions that most of the developers post with their themes. A lot of them require that you reboot, clear the dalvik cache if they do not apply the first time. I have had to go through the process several time in order to get some themes to work.
how u get or kno if u got CM7
thankz:)
Find a theme, download it, open the "theme chooser" app. (if you flashed cm7) then scroll to the theme you downloaded, hit "install" and reboot the phone. Make sure the theme is mdpi format
Some of the DEVS recommend wiping the Dalvik cache too. After selecting the theme, reboot in to CWM, wipe the Dalvik then reboot. If it doesn't work you made need to repeat the process again. I've had to do that several times to get some themes to apply in the past.
