Root Help Choosing A Rom
RickDod3
Okay so I installed MikG 2.59, and so far I like it...but I was wondering if there was a rom that was simple 100% stock but with the wireless tether enabled?
I loved my stock phone, but simply wanted to tether without paying ;)
Also, When I flashed my phone, I lost all my contacts :mad: so I think I missed a step
if at this point all you want is wireless tether, you can flash this stock, rooted rom found HERE and download the wireless tether from the market, found HERE... i'm actually running this rom right now... it is quite smooth, good battery...
EDIT - make sure you sync your contacts with google... then you'll always have them...
Is there anything special that I have to do to install a different rom?
Do I just open the sd card on my computer and deleted the old rom file and replace it and reflash?
Also yeah I thought I had synced with google...but I failed haha Live and learn I suppose
make a nandroid, just in case, and then just place the new rom on your card, do a full wipe, and flash... that's it.. and, yes, you can delete the other rom from your card... get that space back...
Awesome!!!! Thanks!!!! P.s. should I use the odexed or deodex'ed?
Okay, Ran into a problem. When I went to install the wireless tether rom the market says:
"This app is incompatible with your Sprint HTC PC36100"
go to this guide:
http://androidforums.com/evo-4g-all...net-tethering-w-evo-4g-3g-wireless-wired.html.
there should be links to download the wireless tether app. i use the pre9 version with no issues.
Ok so I tried using different tether apps and got a few to work for my ipod, but the tether I need to work with is for my Kenwood CD player in my car to stream pandora...and it says it requires the hotspot app...
Soooo can I mod my stock rom with the Hotspot& Tether fix?
[ Mods ][ 12-21 ] Calkulin's Mods & Fixes [Unlocked Tether l MMS Resize l Reboot Mod] - xda-developers
read this thread for hotspot with gingerbread:
[HotSpot Hack] Enable Hotspot on Gingerbread - xda-developers
Stock? Blah. Mikg is awesome. If you want to go aosp, miui is quite nice and deck's 1.3d aosp build is quite nice as well.
With that said tommytomatoe's modified stock is pretty good.
