Nathan2112
I need some space cleared up on my SD Card but Idk what I can/cant remove from it?? Can I take off some nandroids, previous roms etc.?
You *need* 1 working nandroid on the card "just in case"
I also usually keep at least my current ROM/Kernel on there so I can reflash them as needed
Anything else can be deletedThe ROM will repopulate the SD card with folders as it needs them
