Root help! com.android.settings crashing.
I installed the new leaked music app. I didn't like it so I uninstalled it, but the stock one disappeared as well.
I re-installed the new leaked music app, but now i can't set ringtones on my phone. every time i go to settings/sounds/phone ringtone, i get the process crash.
com.android.settings crashes.
Is there any fix for this? Can someone help me get the apk for the stock music app?
Thank you!
Thank you!
The easy one size fits all answer is to do a factory/data reset. Or you can sbf your phone. You'll find the "how-to's" here: U D G
Do you think it's a good idea to SBF so I can get the OTA update this week? is there a easy root out for DX GB once I get the OTA?
So far GingerBreak 1.2 roots all the current leaks. No on knows for sure if it will root the official OTA update until it os released. If I had to bet though I believe it will root the OTA.
