OP we need more info.
Are you on a GSM/VZW/Sprint nexus?
Were you originally rooted?
What were you last doing before this started?
MY Gnex IS dead AND wont boot it only shows this symbol in a triangle >> ! . and a phone and pc icon beside the symbol !...
Is there a dead android under the triangle with the ! And is the triangle red?
Do you have a nandroid backup? Can you access recovery mode (TWRP or CWM)? This is a difficult phone to completely kill. Worst case scenario head to XDA, grab a stock image and ODIN, and flash the stock image.
You are in Download mode. dont panic, dont worry.
there are ways to use ODIN for the GSM Nexus
however i want to try something else with you first!
remove the battery, and put it back in, hold vol down and power at the same time. does it boot to the bootloader? (do you know what the bootloader is?)
give me that information and i can assist you furter!
i know a little about the bootloader, NO it doesnt boot in to the bootloader![]()
Try holding volume down + volume up and power.
not working with me
it is kind of odd that you cannot boot into bootloader mode, im wondering how you got into downloader mode for one
1- GSM international
2- yes rooted
3- tryes to change the font with https://play.google.com/store/apps/details?id=com.jrummy.font.installer&feature=search_result
