Help HELP! Devastating ICS Bug!
hb21
Hey guys,
I have a Galaxy Nexus running ICS (obviously) and all my phone numbers have an extra zero at the beginning of them. This means that whenever I want to make a call from my phone book, it is invalid.
I tried to google this but to no avail.
Any help would be appreciated.
Thanks!
Hey guys,
Thanks!
Welcome to the forums!
I don't have a Gnex but on my phone if I go to settings>callsettings>assisteddialing I can set my reference country to US. If I set it up for another country, sometimes the 0 is added depending on what country I set it up as.
Hope that helps.
Hope that helps.
I tried searching every single part of the settings but i couldn't find "assisted dialing".
It was working perfectly fine before the reason I think that it's a bug is because it just happened randomly =/
I have the Gnex but have not happend across this issue. Moved to Gnex forum to see if anybody else has found a fix for this.
I had this with the yakjuux build of ics 4.0.1 that came with my telus hspa nexus only in the messaging app... numbers worked fine. I am now using the Google provided yakju 4.04 pics build... everything displays fine now.
