Root HELP: EVO Frustrated - AWAKE TIME
discraleigh
So I have an HTC EVO 4G with all the Sprint Crap that came with it (I hate that stuff). I do really like the phone but I am really frustrated with a few things:
1. Many times I have found my phone not sleeping. Not sure what app is causing this but it sucks the battery dry. I have installed beautiful widgets, Swype and Handcent. None of those seem to be causing problems on any other phones. Is anyone else have this problem???
2. The rebooting issue. I will be driving a long with GPS on and get a call and the phone just reboots.
I have been to sprint and they are no help. Basically - REBOOT with no cause or why the phone is doing what it is doing.. Anyone else having these problems..
I am running stock HTC and now it seems launcher is gone from Froyo.
Download spare parts from market and check partial wake usage...
I thought Awake time didn't matter on Froyo, as long as it was lower than Up time? =]
EarlyMon, Great information! I will have to give this a go. As far as you know though it is not an application in from the market like Swype or Handcent? I would love to have these apps back but afraid to install because afraid it will start the awake 100% up again! Thanks again!
Also, is there anyone out there running Beautiful widgets and not having the awake time = uptime? EVO only... with 2.2
Beautiful widgets is not responsible for your awake time, if that's what you're asking..... but if you're feeling a bit paranoid, you can try Switch Pro, which IMO is a much more elegant toggle package than Beautiful widgets.
Here's SwitchPro at the top of my homescreen (below). You can also give it a translucent or opaque background, which makes it look like the default android toggles. There are also way more than the 6 toggles pictured in this screenie.
I have both of these exact same problems. I have followed the entire "How to fix Froyo" thread and have done 3 hard resets. That said, my battery life is not horrendous and I don't use GPS that much. As soon as 2.2 is rooted, I'm moving to another ROM.
Also, I have neither Swype or Handcent installed and never have.
My fiance's phone haf the 'awake' problem. I noticed her GPS was going crazy all the time trying to send her location. GPS off = problem solved. She's turned the gps back on and hasn't had the problem since.
I use Handcent - no trouble. However - others mentioned and I confirmed that if you use the LED and change from the default frequency on that with Handcent - it _will_ whack your battery life.
Similar to leaving all of your LED notifications on (Menu-> Settings-> Display-> Notification flash).
Also - never underestimate what a bad download of any app can do to screw with you.
I had something like that at one point and the next thing I knew, my syslog was telling me that wifi was cycling on/off faster than once per second and that it was trying to establish WiMAX, giving up, and re-trying - repeatedly - as fast as it could - with 4G _off_.
ThatNewAndroidGuy and asaberan are examples of rational users who have done everything right yet are still plagued by something undiscovered under the hood. Theirs and perhaps a few like them are why we only claim around 95% success with the methods in the How-to-fix thread (and that's not a royal we - that thread has my name on it, but that's all - the info there is result of a great group effort).
ps - Rangergrrl found that by working with Sprint and reprovisioning her phone she was able to get the right performance where a factory reset alone wasn't enough (page one of the thread) - just putting that out there for whatever reason.
Are you rooted? Have you tried updating your wimax and radio? That sometimes solves the issue. There was also a problem with Facebook, I don't know if that's an issue anymore.
