hello guys pls i need your help in my x10. the problem is that i recoverd the phone tp factory and since then the browser dosnt work there is eror and i cant use it what shell i do? pls help me
Remove the battery while the phone is turned on, then remove the SD card and the sim card. Wait 30 seconds, then reinsert the sim, SD card and battery, then turn the phone on and see if that solved the problem
