Help HELP!!! Firmware Update stoped!!!
The box that you had to wait to turn yellow before proceeding will be green with PASS in it on completion.
If you have this, then your all done.
I just disconnect the phone from cpu.
Now I cant turn on the phone and when I am trying to update firmware my computer is restarting.
What can I do?
If your phone wont switch on, then it doesnt sound too promising.
One thing to try is to take out the battery, then press and hold the ON button for about 10 seconds or so. Replace the battery, then press ON button to start it. This is a soft reset, and wipes the temporary memory and empties all remaining power in the circuits.
If this does not work, do as above but after inserting the battery, press and hold the ON button and the HOME button at the same time for 10 seconds or so again. This is a hard reset, and works best if done after a soft reset.
If neither of these works then you phone seems likely to be bricked.
Didn't you have this same problem a week ago using Kies, Narek?
Yes.
Only yesterday I recieved my phone from service centre and now this.
When I am pressing "start" on Odin my computer restarting.
Its unbeliveable my phone doesnt want to be upgraded.
What is the current baseband, kernel and build number of the firmware on your handset, and what version are you attempting to update it with?
