CAN ANYONE TEL ME DETAILED STEP BY STEP INSTRUCTIONS ON HOW TO USE ODIN
"HOW DO I EXTRACT FILES ONCE DOWNLOADED" (EXTARCTING FILES FROM ZIP FOLDER TO ODIN SECTIONS..
E.G I HAVE DOWNLOADED CURRENT 2.3.5 GB FIRMWARE.. I WILL GET ZIP PACKAGE IN MY DOWNLOADED FOLDER..
WHAT DO I DO NEXT ???
DO I DOUBLE CLICK THAT FILE ? DO I SAVE IT ANOTHER FOLDER ??
IN ODIN FILES ARE EXTRACTED TO PDA, MODEM, CSC ETC ETC SO HOW DO I GET IT FROM FOLDER TO ODIN ????
![Thinking :thinking: :thinking:](/styles/smilies/google/thinking.png)
![Mad :mad: :mad:](/styles/smilies/google/angry.png)
How to install I9000XXJVS Firmware on Galaxy S
Prerequisite
Samsung USB Drivers , Download Link
I9000XXJVS.rar Password - samfirmware.com | Download link 228 MB
Odin software Download Link
Charge your phone battery up to a good level
Now follow these steps carefully or refer the attached video -
Phase 1- setting up PC and backup
Install the Samsung USB drivers
Unzip the main firmware file and you will see these files
1. CODE_I9000XXJVS_CL565837_REV03_user_low_ship.tar,
2. GT-I9000-CSC-MULTI-OXAJVS.tar,
3. MODEM_I9000XXJVS_REV_00_CL1059471.tar,
4. s1_odin_20100512.pit,
Take Backup of your contacts messages and other data from your phone. Please note that this procedure doesn`t format your internal memory, only messages, contacts and apps will be erased.
Shut down Samsung Kies completely
Run Odin file which you have already installed
Power off your Galaxy S and wait till one vibrate comes to ensure complete switch off
Phase 2 - Upgrading the firmware
Hold Volume down key+ Home button key and press power on to go into download mode
Connect your phone with USB cable
You should get the message “Added! !” under the Odin’s message box in the bottom left.
Check only Re partition, Auto reboot & F. Reset time in option
Put the files like this in Odin:
PIT = s1_odin_20100512.pit,
PDA = CODE_I9000XXJVS_CL565837_REV03_user_low_ship.tar,
Phone = MODEM_I9000XXJVS_REV_00_CL1059471.tar,
CSC = GT-I9000-CSC-MULTI-OXAJVS.tar
Hit the start button and process will begin
Wait until your phone gets restart and then unplug the cable
You will have I9000XXJVS Android 2.3.5 on your device
![Smile :) :)](/styles/smilies/google/smilie.png)
