fodoom
Edit:
Here's what I did to be able to flash CM10.1:
HTC Unlock
Flash files linked in post #4
Go to Unlimited.io and achieve S-OFF
Flash 4EXT
Format all partitions except SD card
Flash lower version of bootloader (PG86IMG.zip) linked in post #13
Remove PG86IMG.zip from SD card
Install CM10.1 ROM
Boot
Go back to recovery and install GAPPS
Info
S-ON
Bootloader: Unlocked
HBoot: 1.57
Recovery: 4EXT 1.0.0.5 RC8
Current ROM: 1.13.652.2 710RD (Stock ROM, rooted... from JMZ I think.)
Problem
I flashed WILD-FOR-THE-NIGHT-02222013-shootervm.zip using 4EXT. Things seemed to be going great because it got passed the boot animation and was optimizing stuff (I'm guessing its deodexing here.)
Before it was done, it rebooted into a loop. It would show the boot animation for about three seconds and then start over... indefinitely. Long story short, I re-locked/unlocked (don't ask, I typed `fastboot oem lock` without thinking about what I was doing) the bootloader and flashed TWRP 1.1.1 to recover my nand backup. It seemed to hang on recovering the boot image, so I pulled the battery. That was bootlooping too, so I flashed the boot.img that was still in my sdk folder. This made it boot twice but then started up again.
My S-OFF Problem
I made a USB key with Lubuntu 12.something but it says fastboot: not found and adb: not found when I try to run ControlBear.
All I want to do is make my phone awesome.
Thanks!
HTC Unlock
Flash 4EXT
Install CM10.1 ROM
Boot
Info
S-ON
HBoot: 1.57
Problem
My S-OFF Problem
Thanks!
