I used the 8GB card that came with the phone to make my Goldcard. As soon as I rooted, I reformatted the card, so it was no longer a Goldcard![]()
the the image hex edited to the sd card stays,even with a format. ive formated my gold card a couple times and its still gold
No problem....Hey is anyone running the unofficial CM9 on XDA ...and would they recommend it over the official stable CM7.2 I'm on now...and if so why??? Cheers!!!
Great advice guys. Gonna root and flash a rom tomorrow on my old dhd after many years of wanting to root a drvice.
If this goes well, I'll root my galaxy note.
maybe i should download the newest version and read the effin manual meself
i have not actually read it,i just know that when you ask questions on IRC they get very angry if you ask something thats been covered.
ral,what carrier,buid number were you on when you ran it?
Omar Days,how bout you? what is your current software build,and what carrier are you using? (build is in settings/about phone and will be something like 3.12.405.1)
I had to hold the volume+ key and press power to reboot after seeing the red triangle as instructed.
but if we can find one,and the AAHK has successfully changed the main version,having him run it is certainly an option
