Root Help getting out of emergency screen
SARAJEVO
So I tried to flash the CM7 on my phone. When I was done, my phone kept on getting stuck on the boot screen (blue android figure). Another problem was that for some reason I couldn't get into bootloader mode. So I tried this:
[GUIDE] Unbricking/Unrooting/Returning to Stock Optimus M[KDZ]
However in the middle of that process there was an error. Now when I try to turn on my phone or if I just plug it into my PC, the emergency mode screen appears (SW upgrade do not unplug). Now whatever I try I cant get it out of that mode. Help?
Theres a method you can do to boot straight to the recovery. When the phone is off, (take the battery out and put it back in) press and hold the power, home, and volume down buttons. When the menu,home,back, and search buttons light up, release volume down and home.
Trust me I have tried that at least 100 times. No matter what combination I try, as soon as I touch the power button it loads up that (SW upgrade do not unplug) screen. It does it instantly, and no buttons light up. It's like stuck in that mode.
Is it possible that I have deleted the recovery and bootloader software from the phone? :confused:
What was the error??
SARAJEVO, were you able to get out of S/W upgrade screen ? i have the same problem. ive tried everything in this forum and still cant get out of it.
i have the same problem [R&D Test Tools Log File]
13:26:48 : Launching SW update
13:26:48 : Unpacking KDZ
13:26:49 : KDZ file extraced
13:26:50 : Files were extracted.
13:26:50 : LGMobileDL Load.
13:26:50 : Port = -1
13:26:50 : Connecting to phone
13:26:59 : Check Phone mode = 2
13:27:06 : Phone type check.......
13:27:06 : LGMobileDL.DLL Loading....
13:27:06 : _SetAuthMark Ok : wAuthMark(22181)
13:27:06 : _DetachDLL Call
13:27:06 : _DetachDLL Call End
13:27:06 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\MS690ZV7_08.S7_08.P3018.wdb
13:27:06 : Param : moduleDir =
13:27:06 : Param : waitTime = 33000
13:27:06 : Param : UsbHighSpeed = 0
13:27:06 : Param : PhoneMode = 2
13:27:06 : Param : BinVersion = MS690ZV7_08.S7_08.P3018
13:27:06 : Param : AuthMark = 22181
13:27:06 : Call fn_StartUpgrade
13:27:07 : CDMA: wParam = 20, lParam = 420
13:27:07 : Model Dll Msg Not Found(20, 420)
13:27:11 : CDMA: wParam = 6, lParam = 0
13:27:11 : Step : Main Binary Flash Erase
13:27:11 : CDMA: wParam = 7, lParam = 1
13:27:11 : Step : Flash Burning(SDRAM to FLASH)
13:27:11 : CDMA: wParam = 7, lParam = 0
13:27:14 : CDMA: wParam = 7, lParam = 1
13:27:16 : CDMA: wParam = 7, lParam = 2
13:27:19 : CDMA: wParam = 7, lParam = 3
13:27:21 : CDMA: wParam = 7, lParam = 4
13:27:24 : CDMA: wParam = 7, lParam = 5
13:27:26 : CDMA: wParam = 7, lParam = 6
