Try this first..boot into recovery and wipe cache and dalvik cache, then reboot.
See if that helps
See if that helps
nope still doing the same thing
by re-flash do you mean flash zip from sd card
O.k...this is what I think should be done...and I will copy/paste the instructions here....these are taken from this guide:
I kinda edited a little just for you
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
Basically, this is what we are going to do. We will install a recovery (called AmonRA). Then we will flash a rom to get your phone working.
That should do it man!
If you have any questions after reading this, just ask so you are clear on the process.![]()
Just made an account specifically to thank you Mikestony. My son was given an old phone from a family member to use as a "mini tablet" and I didn't know it was rooted. I factory reset it and got it in the same state as the OP. Your instructions were perfect, just what I needed. It works perfectly now. Thanks! Now I'm eyeing my EVO 4G LTE and wondering if I can root it to get the Bluetooth working again. . . .
