Help Help help help help help!!!!i bricked my phone
I have a massive problem the other day launcherpro kept force closing. I couldnt do anything. I called cricket and they had me do a hard reset and nothing. I took it into the cricket shop and they said that it was bricked. in the ABOUT PHONE OPTIONS, it doesnt even no what model it is. it says unknown,and it says the same thing for the firmware, baseband version, build number, all unknown. same for the network, mobile network type, phone number, IMEI, IMEI SV, WIFI MAC ADDRESS, BLUETOOTH ADDRESS, just about everything that is needed to operate isnt there. and im sure there are other things unknown i just listed what I thought was important. Im so STUPID, all this for a stupid DROID sound on bootup. I change over the BUILD PROP that I got from MYASCEND.ORG listed as BUILDPROP.TEXT and now i have a brick if anyone and i mean anyone can help i would be FOREVER in your DEBT. they said the only people that could FIX my phone is huawei. and im a single parent with a 3month old girl and NO extra MONEY. I could really use the HELP. Let alone a phone incase there is an emergency. please be patiant with me as the internet is my only way of communication and i wont be able to get back on till later bc my father needs it for work today.
NY...did she say if it still works at all?
That is why I said to re-flash
Upvote 0
Ciabatoni....do what NY said to do. Here are the instructions for Cricket users:
Huawei Ascend - Flash Back to Stock - xda-developers
Force Update Method
(Recommendation : When the OS of handsets could not start up successfully)
Download the Following Package:
Cricket Stock Recovery Package
d97ed410ffa518c689e2444d21007daa M860V100R001C153B251SP03.zip
1) Copy "dload" folder to SD card
2) Switch off the handset ,then press "Volume Control Upper Key +End Key+ Power Key"
3) Showing successful
4) Remove battery one second ,then power on ,waiting till the os start up
Normal Update Method
2) Settings--SD card & Phone storage--Software Upgrade
Upvote 0
you guys have no freakin idea how much I love all of you's, my phone is back online back to stock. that was a small price to pay for a few links. you guys are the greatest, I wish there was a way i could repay everyone. but all i can say is thank u thank u thank u X INFINITY you have kno idea....thank you Joser116, thank you Jazziette, thank you NY11725, thank you Rolltide. noew im not scared to do whatever i want anymore, LOL knowing i have sum back here and this nifty dload. should i leave the dload on my sdcard or does it leave when you flash the phone THANX AGAIN
Upvote 0
No problem. Send me a PM everytime you need some help. And yes, the dload file stays in the SD card. Also, just for future reference, which solution worked best for you?
Upvote 0
BEST TECH IN 2023
Smartphones
