I am doing that but says can't find my device. Debugging is on.
Do I need to run both versions of UnRevoked or can I just run UnRevoked Forever.
Cool beans.
Is late here and gotta work so I will finish tomorrow and will definitely be back to let everyone know how it went.
I want to thank you all for all your help so far. There is no way I would've attempted this without you and for sure no way I would've succeeded with all I have done so far without you all. I appreciate all you have done.
This is what the beginners (like me) use to build a custom ROM:--snip--
Edit Again: Got it. Am now all set. Again I want to thank everyone for their help. All I am needing now is to know if there is a link to either aide me in customizing a rom or requesting a certain custom rom(optimal since I know nothing about coding)?
Yeah, all that info is like, way above my head, I would venture to say it's close to near earth orbit, it that's high.Even if you're not planning on creating a rom that's great info on some of the things that makes them tick. I wish there was a way to digest all the incredible info like this I come across here.
I got to the point for all my "likes" that the oldest ones are gone!I "like" the info so a link is created for me in my profile.....I've creadted a library of way more that I can digest any time soon like I'm sure you have.
Thanks for all the help. All of you have been great. Unfortunately I am still basically where I started after literally loading every rom listed here and xda and some from places so dark that no one in their right mind would venture. So I have a new set of questions....
As it is I am using CyanogenMod7. Luckily it is closest to what my ultimate goal was because I dont use Googles Market for anything I can get elsewhere anyways. Unfortunately it leaves me a little put out. I am able to open Twitter from all links inside emails and browser but not YouTube or Facebook and I dont understand why 1 will work and not the others so maybe someone can fill me in there. Secondly since there isnt any Google Framework other than YouTube running on my phone it doesnt allow me to sign into G+ App. Anyway I can bypass the login process and have it use the web like Twitter to sign in or is there another quick fix to bypass the activation process?
I would freeze them first with Titanium Backup, then, if your phone acts funny, you can unfreeze them.I have flashed gapps so any idea how I remove what I don't want? Im would like to remove GTalk,Market,Gmail for sure because I don't use either of those.
I flashed a rom Black bean and got stuck in Boot loop. Flashed cm7 and now am told I have an international phone and my Data doesn't work. Have flashed nearly every rom I can and doesn't fix it. How do I get my Data Profile back?
I dont think so...is that rom made by Robobob?Got it fixed. Not sure what was going on but it started working again as mysteriously as it stopped.
Another question.... I found a Rom that looks fairly nice but it doesn't recognize my 3G. Now it does state that it was intended for Japan but is there a way I can use the Rom and flash a Kernel that will connect to Sprint data?
When you say settings, do you mean app settings?Name sounds right but really not sure. Do know it was intended for Japan but I figured why not. Gave it up.
Do have what I hope is my final question.
I have flashed every rom I can find and now am deciding to make one my daily. Problem is it seems I am unable to clean my phone from all the old files. Give an example: A week ago or so I flashed Energy Rom. Used it for a couple days. I flashed it again yesterday to take one more look and all my settings were still there including Bookmarks. I didn't do Nandroid and have been Wipe Data/Restore 3x and ZZZSuperWipe x7 between every rom. So how do I clean my phone from all these old files so I get a clean install on whatever rom I choose to use for the next 2 months when I get my upgrade? I have also formatted my sdcard thinking that would help but no go.
