Root HELP....How Do I Get Boost Mobile Prl......
dollardagreat
I Changed The Prl To Speed Up My Transform, It Work For 2 Days And Today It Just Jumps In And Out Of Reception......3g Signal But No 3g, No Data.....Barely Get Calls, Miss Calls All Day.....Can I Go Back To Boost Mobile Prl Using CDMA Workshop???? Can I Get Boost Mobile Prl????? Helpppppp
I Tried Them All...Some Work Well But Today It Just Cut Out..... 61007 was the Stock PRl On My Phone I Put That Back On And It Still Jumping In And Out Of Reception Or Signal......Im In New York......On CDMA Workshop Do I Still Press Samsung Sprint Even Tho Its Boost Mobile Or Do I Press Something Else??????
no choose samsung default
For Password I Choose Samsung Default Which Is????? It Dont Say Samsung Default In Cdma Workshop......Thk For Helping.....
no i actually meant choose samsung default, where th samsung list starts right above it you should see "samsung default" choose it and hit send it shoudl say phone unlock then change the prl
just found something out heres what ya do, go to settings about phone system updates choose update profile and when thats done choose update prl when thats done reboot your phone and you will be on stock prl
Thks And Ur Rom Is Fiya......But After I Did That Still Cutting In And Out Of Signal....I Dont Understand...It Was Working Flawless, Then Just Stop Getting A Signal.....I Get No #3g And Barely Get calls.....
It Still Cut In And Out Of Reception...do U Think It Could Be The Rom.....
are you sure you are in a good location??? when did it start?? when you changed the prl?
i doubt its the ROM as the ROM has nothing to do with the networks but to be safe boot into cwm and do a advance system restore on the ROM and reboot
Im In A Gud Location.....my 3g signal is up but no internet comes on......I did everything u said.....I change the prl 2 days ago to 01120,60676, 60677 and they work fine until yesterday and this started to happen from nowhere, so i went back to 61007 and still continues.....i updated the profile and the prl last night and now i could make calls but still no internet.......
go to settings about then wireless and networks scroll down too mobile networks is 3g check?
I Did That.....Change the prl 2 days ago, it work fine, yesterday it just stop working....
Call boost there could be a tower in your area that might be going in and out or have a outage. Even if its not the tower explain your problems but Do not tell them you changed your prl and they will help you through the steps of manually reprograming your phone.
Boost Tried To Troubleshoot but it didnt work, so they told me to cal samsung and samsung told me to send it in for repair....i went back to stock everything system, prl, etc, should everything be ok..... I used ur rom 02, 03 and 04......but i went back to stock.....Do U think It Will be a Problem?
ohh ok, and no not at all go back to stock and see if it makes a difference
I Tried To Clear Dalvik....Nothing Is Working.......Still Barely Any Reception With 6 Bars And A 3g Signal..........I Can't Make A Call Or Go On The Internet.......
