JohnnyBravo1000
Android Expert
I was planning on flashing a ROM.
Basically, I created a partition for Apps2SD and I was unsure if it had created or not.
I used Quick System Info, and it said "information unavailable", so I'd assumed it hadn't worked.
I think it has worked, as I only have 14.35GB of my 16GB card remaining, and I'm sure I had a lot more than that available, even with the contents I previously had on it.
How can I remove the partition to make the SD card "whole again" so I can begin this process again?
