Help!! I blacklisted a number
Evan55
I accidentally blacklisted a number and I can't undo it. I have check my settings and that is uncheck. I miss my bb:confused:
Beware I'm new @ this.
I don't recall blacklisting being any easier on the BB.
Per the post above, it's difficult to assist without details. What settings? What app? How are you testing to see if the number is still blacklisted?
there is a setting in handcent to 'show all blacklisted contacts' once you enable that you can then un blacklist it
For CyanogenMod-6.0.0 - you can go into seetings, call settings, scroll to the bottom and click "blacklist"
or in your address book, you can long click a contact and click "view contact" then "options" and you can choose to "send calls directly to voicemail"
Thanks for that, I had done the same as the OP and was scratching my head how to sort it! Running cyanogenmod 7.0.3.
