When I try to boot into recovery it goes right to the HTC EVO 4G white screen and just stays there.
Any ideas what to do?
Would flashing an alternate recovery in ROM Manager work? Or the All ClockworkMod Recoveries?
Help!!![]()
Power off. When phone is fully off, press power and volume-down at the same time. Keep them held down until you see the white bootloader screen appear. It will scan for some files and then show you a menu. Scroll down to "recovery" with the volume-down button. Press power to select it.
Now you should see the Evo white splash screen. After a short wait, you should be in recovery. If it stays on the white splash screen, it sounds like your recovery image is bad. Assuming you have the engineering bootloader, you can use fastboot to flash a recovery image manually. But first, let's see if you can get to recovery with the method above (instead of from ROM manager).
Thanks guys for the help. So glad I got this resolved!
If you're still having trouble doing things from ROM Manager, uninstall it and reinstall. My full root was in a weird state because I think I did what you did: full root, then flashed a recovery with unrevoked. It was like a 2.5.0.1 beta at the time, and ROM Manager didn't like it.
Do you really need 0.76.2000 (nand unlocked) ?First thing to verify is that you have the engineering bootloader.
Power off your phone. Then hold power and volume-down until the bootloader appears. On this screen, you should see:
SUPERSONIC EVT2-3 ENG S-OFF
HBOOT-0.76.2000 (PC3610000)
If you don't have that 0.76.2000 version, then you don't have the engineering bootloader and you will need to re-root your phone with a full-root method. If you DO have the engineering bootloader, then you should be all set to proceed.
For some reason I have 0.79.0000 on my phone and I have been flashing ROMs no problem.
Help!!![]()
