Root help i cant call
chicomostoc
help I cant make calls when call to voicemail says: missing voicemal number: no voicemail number is stored on the SIM CARD
and I cant make any calls dialing gets stuck and says network busy
and the status says my phone number: unknown
and prl 40000
and prl 40000
Looks like test mode. Press # and see what happens. If it goes to hidden menu then follow my test mode guide located in the atr guide sticky
Dont matter what you did. Test mode happens for reasons no one knows. LG doesnt even know.
Youll find the guide in the sticky. Good luck.
thanks fuzzy everything worked perfect, lacking only the MIN, but call to metro and all good.
and save everything and my MIN, so the next time I do it myself
Very smart. ;)
Glad you got it working. Dont understand how people have problems with this guide. :rolleyes: Some people just cant read.
Glad your good though ;)
Very smart. ;)
thank you very much ... is very simple as you say .. only need to read step by step ..
Your guide has many steps, but you did the most simple for the most dummy can do it
thanks for making all simple for us ...
