Root help i messed up
Tmac
I was trying to flash gb and got stuck in a boot loop have never sbf how do i do that thanks for your help
OP don't let SBF'ing intimidate you. Its really not that bad if you follow the instructions Steven gave you a link to. I actually prefer to SBF sometimes now so that i know i'm starting fresh.
you will be fine...SBFing is really not as tough as you think...it involves a couple key presses...thats all...
for future reference however...im not sure where you got your instructions for flashing GingerBread from....but step number 1 should have been to SBF back to stock...that is why you bootlooped...
SBF'ing is really easy. You can actually do it with your eyes closed. I know, I did. click button.....close eyes......pooof......all done.
