garryw1305
Hi all,
I really would like some help!
I've installed a custom ICS ROM on my SGSII (Resurrection Remix 1.8.1) and am loving it! The only minor problem I'm having is that I did quite like the stock widget with the Samsung Firmware titled "Mini Paper", which was "postit.apk".
At first I tried simply running the .apk file to install the app but an error said "Not Installed!" after attempting to install it. Then, I found that some had to be moved to system/app folder, given rw-r-r permissions, wipe the dalvik cache and then reboot the phone for it to work.
I have tried all the above methods and the app does now show up in the system/app folder twice (one as the original "postit.apk" and the second as "com.sec.android.widgetapp.posit.apk"), but the widget still does not appear listed in the 'Widgets' list either on the home screen 'add widget' menu or in the 'Widget Drawer'
Can anyone please help?
