Help! Is this a serious security problem?
andy_48
I have a notification that I do not recognise: "Slides requests sensitive permissions". It is in red with an icon that is a red key on a white background in a red triangle. When I clicked on it it seemed to start an app analysing my phone and SD card memory.
I freaked out, powered off the phone immediately and whipped out my SD card. I powered it back on and this notification reappeared.
Any idea what this is and is it safe? If not, how do I get rid of it?
Samsung Galaxy S4, Android 5.0.1
Is the phone rooted? If not, it can only get so far, and a factory data reset should clear it up. Have you installed any potentially pirated apps or from weird 3rd parties? Not asking to be accusatory, but that's a common vessel for the transport of malware.:(
Not rooted. Haven't loaded any new apps for weeks.
Thanks for you reply, by the way. Appreciate it.
That's what are little community is about. Welcome to AF.
I've tried searching based on the error message or the description but am coming up empty. Maybe another member will chime in with ideas or if you see it again, we can get a peak at the screenshot.
I got this notofication also. Here's a screenshot. Looks evil. My phone is rooted and with TWRP, Galaxy K Zoom, Android 4.4.
I'm seeing this too. Looks like a brand new phenomenon. This thread is the only search result on Google for the query android "requests sensitive permissions".
Here's a large screenshot from my Moto X running Android 4.4.4, not rooted:
I'm developing a program on my phone which does nothing special apart from requesting publicly accessible files from the external SD card. After upgrading, ES-File Exploring started saying that my program demanded sensitive permissions!
ES Explorer goes too far!
Honestly I'd get rid of clean master as well. Cheetah mobile is notorious for malware apps. I guarantee if you search the site for cheetah mobile you will come across many threads telling you to uninstall anything made by them.
Also, as far as clean master or similar type apps, take a look at these threads as you might change your mind about using them:
http://androidforums.com/threads/why-you-dont-need-a-task-killer.335110/
http://androidforums.com/threads/pu...k-killers-ram-optimizers-and-the-like.896663/
Es File explore used to be good back in the cupcake/gingerbread days as a free root browser with a good ui and networking abilities; however, they did a ui update with ice cream sandwich and it went downhill from there. The best free one from the store at this point in time is probably JRummy's Root Browser; although, i use CMfilemanager because it works great and has no ads only thing its missing is the ability to read .db files.
+1 for root browser. I use that along with x-plore file manager. I settled on those two a long time ago and have never looked back.
