Help me out!
Welcome to the forums ValueTech, glad to have you here :)
Have you gone into the keyboard settings and turned it off, it usually resides in there...
Especially if you have downloaded a different keyboard, to access those settings there is usually a button you can long press on the keyboard, typically located in the bottom left.
Hope this helps :D
Hello and welcome to Android Forums. :)
DC has given you some good advice on how to get this done. Hopefully it works for you.
Thanks for joining.
