miltonpulse
I have a android pulse and i set a pattern lock thing but i forgot it, i need my gmail and pw but i forgot the password and the security question so i cant unlock my phone. PLEASE HELP what shall i do?
Does anyone know what i should do? because im paying monthly for this phone and i cant even make a phone call. I have phoned t mobile and they have said i need to take it to my closest store and they will repair it, but i need a debit card and i only have an electron.
Gonna have to wipe it. Hopefully a wipe on there is the same as other Android phones.
Turn the phone off.
While holding the home but hit power and continue holding home.
When you come to a screen with a triangle and an exclamation point let go of home.
Hit alt+L to see the text.
Hit alt+W to wipe it.
Hit the back and home buttons to reboot.
You're gonna have to set everything up again but at least you can get into your phone.
What is a alt+L there is no alt l on my phone
When i hold the end button and vol down and press power it takes me to a blue screen called fastboot or something. but it comes up serial number unknown and nothing happensOh right. Pulse. Ok.....after you get to the triangle screen, press home and power again but don't hold them. That should bring up a menu.
My pulse has been blocked because i failed the pattern code to many times now they are asking for my google account and password which i dont remember either. What should i do!!! I cant even make a phone call or text!!!
I didnt get offered to put in a secondary e-mail
for ID.
HOW THE XXX DO I FASTBOOT THIS PIECE OF XXXX
