are you sure???if i press the code,,the firmware reset and delete all my memory internal.if i do it,,will my camera normal again???
youhave experience sir?
at the first day i bought,, i opened the camera and testing 2-3 menit it's okay
and 1 week next i opened the camera,,it was yellow thing..
i have testing factory reset,,it was back to new buy,,the camera okay,,
but tomorrow it back yellow again,,
factory reset and hard reset same????
Heyyy.. m sure.. it just a defection of an application.. like I have installed "Chainfire 3D" on my rooted galaxy Y and then my screen becomes all rough n dat was super annoying!!!
U need a firmware reset. but backup all ur important data first..
so lets get started.. Switch off ur phone> Boot into Recovery Mode [press volume up+down+home buttons all together]> Now touch is disabled here. use volume up/down keys for scrolling & home button to select> select "Wipe data/reset"> select "Yes-Delete all users"> wait few seconds> select "Wipe Cache"> select "Yes-Wipe Cache".. >wait> select "reboot system now"..
Now phone will restart..
First boot may take upto 10 minutes so b patient..
PROBLEM SOLVED!!
if it if not works then goto dialler and dial *2767*3855# to reset ur whole android system n firmware!!)
for any help u can sms me or call me on +918418063050 !!![]()
i have doit,,but no changed..
my camera still error like the picture in the top
Have you fix your camera problem? I have the same issues. please reply.MY CAMERA WHY???my galaxy y version is gingerbeard 2.3.6
my camera is yellow effect,,i dont know what going on
