Help me pls
hi I'm wondering if there is away to remove preloaded apps that came on my zte merit straight talk pre paid phone? So many apps that are taken up my memory space.
There is no way to remove preinstalled apps on any phone without rooting it. If you are rooted Titanium Backup makes it really easy, just make sure you don't delete critical system apps.
Welcome to the forums! :D
Like my friend above me stated, you need to root your device if you wish to gain access to deleting the preloaded apps on your device.
Feel free to read up more about rooting by clicking the "FAQ" link in my signature.
Thanks for joining :)
Welcome aboard and thanks for joining!
As stated above, there really isn't a way to remove preloaded bloat without rooting.
If you decide to go the root path, my advice is just to freeze the apps if it's a system app that way if you need it in the future, you can un freeze and it's there.
Freezing disables it from the system, so memory will free up until it's unfroze.
DS
