Root Help Motion Bricked
jmarsh667
Won't go into to Emode or anything at all I can only get the touchscreen buttons to light up for one second. All I did was turn of and restart and the phone would not start any help or Ideas guys?
Connect it to the charger. Will it show charging screen? if so, i think you still (some kinda)have hope.
Also, hold the both power buttons and power until the screen lights up. You said in your post that it just lights up, if so,
connect it, do the unbrick guide, and hope the motion is in e-mode, it just doesn't want to show itself.
What did you really do? Rebooting your phone can't brick it...
it wouldn't turn on at all the only lights that turn on are the three buttons on the bottom no screen or anything and I honestly didn't do a thing just the power off and restart and it wouldn't turn back on. Kinda pisses me off bc I've flashed many devices and never had a problem so I do know what I'm doing to a degree. I work on PC's constantly and can usually fix just about anything and have fixed many other android devices. I just don't even know what happened to this the screen won't light up only the buttons.
Also no I've connected it to the charger and it won't show that its charging nothing nada thing. I've tried both volume down and power on also volume up and both at the same time and I can't get it to do anything but light the three buttons at the bottom for one second if I hold the power button for 5 or 10 seconds
This happened to me too. Plug in the charger don't press the power button. Just press and hold Vol up + vol down.
It will eventually boot into emode.
Or if that doesn't help (without charger) you can try pressing Power+Vol Down and hold until you see factory reset.
Oh wait i think i know the problem..
Is the battery charged? If it isn't, connect it for a while. I had this before and now i remember it.
Let it charge for 15 minutes, try the wall adapter, if that doesn't work try the connecting the USB to a computer to see if it charges there. After 15 minutes, try turning it on when it's charging.
Tried all of that guys and Nothing worked thank you very much though. I am pretty good with android devices along with most other computer/mobile devices this one just happened to completely die I brought it to corporate and they said it died on it's own and is being replaced for free. I did try everything mentioned above and nothing whatsoever would even turn the screen on.
Yea, corporate stores are great at replacing these phones :D
I recently killed my 4G radio, they replaced it within 5 minutes.
But they did, however, forget to program in my phone number :eek:, fixed it myself ;)
Did you do it from the NAM programming menu? :o
