Root Help! My phone is stuck on ladscape mode! CM7
JBOY11
Member
Hello,
Need some help. I must have accidentally pressed something while my phone was in my pocket and now my phone is stuck in landscape mode. I've tried looking all over in the settings to change it back, with no luck. I'm running CM7.
Any ideas?
Thanks!
Hello,
Any ideas?
Thanks!
hmm, that's wierd, try booting into recovery, wipe cache and dalvik cache.
It's a shot:)
Edit: I just thought of something else, depending on what recovery you have, there might be a wipe for rotation I believe
The man himself who helped me with rooting my phone for the first time, a year and a half ago. :)
ADW Launcher
check your launcher settings and you can even try and wipe cache for the launcher and see if that helps. if not then do what mikey suggest, wiping dalvik cache and cache in recovery.
or you can switch launchers. i really like nova launcher. go launcher is another one. i never really like adw to be honest.
I reset ADW. It worked, now fixed. Thanks for the responses!
Shot you a private message.
