Root Help my phone will not boot
nameless1
I failed to RUU my phone back to stock and now it only boots up to the bootloader and will not go into recovery. The phone is on hboot 1.58 with s-on and relocked, please help!
You can't run the RUU while s-on because you are on the new hboot.
I'd suggest unlocking the bootloader again, flash or boot recovery via fastboot and wipe and flash a stock based rom like Harmonia or negalite blue rom to get up and running.
Or any stock based rom of your choice.
Thanks Brian, finally got the phone going again by following your advice and using the easy guide to get out of bootloops. I'll make sure the phone is s-off b4 running the RUU again.
