Hi, Could someone please tell me the easiest way to unlock a Hero on Orange network uk, and then install android 2.1. I will be using a 3 sim in the phone.
I'm very new to all this, so please could you make it simple to understand.
Thank you.
Ok, then. Slug's link is all about removing the orange branded firmware. (That's the only way to get 2.1 at the moment since Orange haven't released their branded firmware).
But like Slug said there are risks; the unbradned 2.1 isn't compatible with a lot of orange phones and so it's not recommended to try to debrand it.
As for removing the Orange network lock, you need to buy an unlock code. You might run into trouble entering the unlock code, so if you do, have a read of this thread.
