Root Help needed somewhat ASAP
Long story short, had problems with CM7 and had to do a lot of troubleshooting. Well tonight I flashed the "alternate" recovery on Rom Manager and then flashed CM7, after doing so I can no longer flash a good new rom. Instead of the inital setup for a new phone/rom it just loads the home screen without any market. I've tried backups and everything. Rom Manager shows me using Clockworkmod 3.05 yet my manual recovery is Amon-Ra.
Please help!
Edit: If I try to run an older Clockworkmod version I get a message saying "Error while trying to run privelaged commands"
yeah you should not use rom manager if you are going to use amon ra. rom manager is the front end for clockwork mod. so if you have amon ra as your recovery, rom manager may not work properly, if at all.
as far as the market goes you need to flash the gapp file as well. here it is Downloading GApps...
word of advice i would not use rom manager. do everything manually. it will save a lot of trouble in the future. rom manager has been known to be buggy. amon ra is a much better option.
