Root Help needed!!!!
Hey all,
I rooted my Ally last night (actually, one of the guys at IRC remoted into my computer and did it for me) and then he had me try to flash velocity 1.1 on my phone. It didn't work, so I cleared the cash and dalvik and also selected ALL/factory reset. Now I cannot load velocity at all (tried a lot), and I cannot even turn the phone on to load the stock rom. All I can do is boot to recovery (that was loaded by the IRC guy). No back up or anything. The nicest thing about it is the the IRC guy just bailed on me without even telling me he was leaving. Now I don't have a phone, and it won't boot to anything...thanks a lot. What do I do from here?
What SW version did you have before you rooted? If you had a 2.1 variant you would not be able to flash Velocity > 1.
My suggestion would be to use the nandroid restore SWC made in this thread
unzip onto your sdcard to a subdir of Nandroid/Mem=223/ as he states in the post, If you had 2.1 before the root, use the 2.1 nandroid, if you had 2.2 use the 2.2 :)
