Root Help! Phone keeps rebooting and CMW won't work!
lopez33
Hey Friends! So after returning to my triumph from an SGSII, my phone is all wonky now. I had deactivated it to switch phones, and would someitmes use it, and it would work perfectly. BUt when I switched back to this phone, it started rebooting itself randomly. THe battery has been depleting super quickly and when I access CMW to try to reset it or do a backup, it comes up blank. (CMW will load but when i select any option a blank screen with the logo appears)....aaah is my phone doomed>?
Just went through something like this. I think it's the battery. $12 on ebay for an official one
Although I don't think this is ur issue, and its not about ur rebooting, some cwm I've used had the power button remove all text and just show the background image, which in a few I actually liked, but Id say check that in regards to the cwm problem only, cause even if the battery is ur culprit in the rebooted it shouldn't cause cwm to appear blank Unless the battery is so dead its actually shutting the phone off by time ur getting into it
