damule6666
Ok this is a bit long but i am at wits end..
I have tried both methods of unrooting my droid.
I installed rsdlite 4.6 and the proper 64 bit driver. And the update.zip file. i do as it states. I plug droid in, turn on while holding up on D-Pad. I get a black screen that says:
Bootloader
2C.6C
Battery OK
OK to Program
Transfer Mode
USB:
Then it says to open rsdlite 4.6 and so i do. It opens and my device is not there. So i go to Config. and select DeviceID Options at this point i get the error message saying:
Motorola RSD has Stopped Working and i get the selections of check online for a solution and closing program or Close program. if i select check online it waits and searches and just closes..
The other way i did was like it said to:
assert failed: !less_than_int(1259199777, getpro
p("ro.build.date.utc"))
E:Error in /sdcard/update.zip
(Status 7)
Installation aborted,
Thats all i keep getting..
Any ideas would be appreciated.
Also is there a special way of opening rsdlite 4.6 as the administrator?
I dont mean to come off as a dumba**. I rooted and over clocked and switch roms all the time.. But this is just NOT working for some damn reason.
Thanks
AJ
Bootloader
2C.6C
Battery OK
OK to Program
Transfer Mode
USB:
- Download 2.01 stock update.zip
- rename the downloaded file to update.zip (if you don't see the .zip in the downloaded filename don't add it because the file extensions are hidden from you.)
- mount Droid to computer
- copy file from computer to root of sdcard
- unmount card from computer
- hold X while rebooting until SPRecovery screen comes up
- install
- allow update.zip
- install /sdcard/update.zip (depreciated)
(Status 7)
Thanks
AJ
