Root Help pleeeease!!!!!!!!!!!
that one dude
Ok I have no idea why but my clock app just disappeared any way to get it back it was there an hour ago now its gone wtf this isn't the first time an app has just disappeared. Thanks
what did you do to make it disappear? what rom are you on? you can try and wipe dalvik cache and cache and re-flash the rom. you are not starting over as you will not be wiping data.
Well its happen before when I uninstall an app I hit uninstall and then it asks to press ok right well at the top it shows a different app than I'm trying to uninstall I catch it most of the time I think that's what happen and I'm on mik3d btw
then just wipe dalvik cache and cache and re-flash the rom.
That sounds like a very dangerous bug and I would recommend reporting it to the ROM devs. You'd be stuck if you tried to uninstall a bloatware app and the ROM uninstalled the android market instead.
your phone is going to transform and grow a really long arm with an even abnormally large hand (the size of a large frying pan) then smack you with it. I know, it happened to me.:rolleyes:
Yo crack I think about u even when I'm not on this site I really do I ponder over the thought of driving through the streets of Detroit and seeing a crack head(like the one in your pic there) smoking rocks and flashing roms on his evo. And i wonder why hasnt he had to sell his phone for crack..........
Did you by chance move the widget to your sd card? For future reference, it's always a good idea not to move any widgets to the sd card
No I didn't thanks tho. I did wipe and tried reflashing still didn't work so I said **** it and did a nandroid restore. Thanks everyone for trying even u crack!
This exact thing happened to me about a month ago on mik3d. I was uninstalling another app and somehow lost my clock- i.e. I wasn't able to set my alarm. Anyway, I actually found it "frozen" in my Titanium Backup list of apps under [ALARMS] Clock. If you using TB, you should be able to go in and unfreeze it. It worked for me- maybe for you too if it happens again. It beats having to do a nandroid restore.
