B bradshly Newbie Jul 6, 2012 #1 How do i root my HTC desire HD 3.2.5 or downgrade to root. I'v tried everything and it always fails. Thanks
AntimonyER CHANGED FROM AF ADDICT MIKESTONY Jul 6, 2012 #2 Hey, I moved this to the All Things Root Section. Thanks for understanding.
scotty85 Extreme Android User Jul 6, 2012 #3 the AAHK is the root standard for the DHD and inspire 4g. there is also a manual guide,if you prefer doing things yourself in cmd http://androidforums.com/desire-hd-...ualy-downgrade-root-inspire-4g-desire-hd.html
B bradshly Newbie Jul 6, 2012 #4 Thankyou i managed to do it but now my phone has no IMEI :S i can get signal because of it. No how to repair IMEI?
scotty85 Extreme Android User Jul 6, 2012 #5 Try running the latest ruu for your carrier,or the latest unbranded ruu if you're unbranded . After that you may need to update prls,or add apns,but the aahk should not have done anything thaats unfixable
scotty85 Extreme Android User Jul 6, 2012 #7 do you know what your build number was before you ran the AAHK? that would make it easy for us to find the correct RUU. if you dont have that information,who is your carrier,and wwere you branded or unbranded before? as much info as you can give will help
B bradshly Newbie Jul 7, 2012 #8 I have no idea sorry. My carrier is three and im in UK if that helps thankyou
