So should I just do again all the procedure previously done with odin and so on following the guide I posted before but using a new CF?
And should I use this one:
CF-Root-SGS2_XX_XEO_LPQ-PROPER-v5.4-CWM5.zip (use also for LPE)
or the one you posted:
CF-Root-SGS2_XW_OXI_LPF-v5.5-CWM5.zip ?
Because in the forum where chainfire posted these kernels there is also written this suggestion:
"Help! Which file do I use ?
Go to Settings -> About phone -> Kernel Version. Note the string present there:
2.6.35.7-I9100XXKG1-CL349526
What matters most (KG1) in this case, is in bold. Try to find the matching file under downloads:
CF-Root-SGS2_XX_OXA_KG1-v4.1-CWM4.zip "
Edit: my LPQ should be similar to LPE, so I will go for this:
CF-Root-SGS2_XW_OXX_LPE-v5.5-CWM5.zip
and hope well..
Thank you, really, I have had much support from you and I will try to help others as I can, hoping this issue of mine will be useful to someone.
Tonight I will try to do the root again, then I will let you know how it went
if you have other advices about how to root again an already rooted phone please let me know
and hope well..
just like dread said you helped me resolve my problem! Amazing forum guys, thank you so much, really, thanks lunatic
