VMuser
Here is my problem with an LG-Optimus V: Phone will not go into recovery mode.
When the recovery mode is started, it goes like this:
Android system recovery
Do not pull out the battery
Formatting DATA:...
Formatting CACHE:...
Factory reset...
Rebooting...
Then it reboots into Cyanogenmod normally.
I need to go into recovery to install a stock ROM, and activate the phone.
Here is how I got here:
My son rooted the phone and installed Cyanogenmod7 to test, then when it came time to activate the phone, he was somewhat haste and push factory reset.
I need a step by step instruction how to get the phone back to stock so I can activate this Christmas present. I am told that if I am able to get it into recovery the rest is easy, but if possible a step by step instruction (with all the right links to the right ROM/recovery) will be greatly appreciated.
Here are the details of the phone/OS
Model number LG-VM670
Android version 2.3.7
Mod version cyanogenmod-7.2.0-RC0-LG-VM670-BobZhome-12082011
Build number GWK7412082011
Kernel version 2.6.32.9-v3.4
CPU info ARMv6-compatible processor rev 5 (v6l)
Than you in advance for your time!!
Formatting DATA:...
Factory reset...
Rebooting...
